1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | hey guys, just bought a 1979"Camper Special" that has a running 350 in it for a project. It needs a rebuild and was wondering if anyone knew where to find the correct #'s off the block to see which motor i'm dealing with b/f i dissasemble it. it may or may not be the original. it's a duelly so i assume it's a one ton, correct me if i'm wrong.
daren | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | they are either on the head(s) or on the intake manifold,i got a 79 gmc sierra classic that has the original motor and the numbers are hidden under 33 years of grease and grime there, so get a wire brush, wd-40 and some rags and see if you can find em, that should give you a place to start. let me know how it goes.
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Small blocks are stamped on the front surface pad,on the block. pass.side,by the water pump bolt hole.Should be all the numbers you need to see.It should be a flat spot. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | There is a machined pad just ahead of the passenger's side cylinder head. The 2 or 3 letter suffix at the end of the stamping will identify the original application. Virtually all the truck engines with 4-bolt main bearing caps have a "T" as the first letter of the suffix. Jerry
| | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | going out to look see. thanks
daren | | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | ok - unfortunatly i found out that according to the #'s i have a 305 v8. good enough for this project, but unexpected in this truck. it's out of a '83 parisien? i think it said. for what i paid for the truck, no harm. runs to good not to use though.
daren | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | You'll need more than the 2 digit suffix code. You will find the block is stamped with a casting number and date behind the driver side cylinder head. Combine that info with the suffix code (2 letters in front of the passenger side cylinder head).
