| | | Forums66 Topics128,048 Posts1,055,539 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | Not sure if we have a place to talk about windows. Trying to install my side windows back into the rollers. Driving me crazy any help would be great.
thanks Brett | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Not sure exactly what the issue is but just wanted to mention that you have to remove the ventilators to install the glass. Before I had new window channels and fuzzies I could pull the glass out of the lower channel and lift the glass out with the ventilators installed. Once I installed all the new pieces parts though everything is back to factory spec. and the ventilators needed removed. Not a big deal, but a good thing to know. Hope that helps.  John | | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | John, got that far. Just wish I new what order to put them in. Got the glass in, then the vent window just can't get glass in rollers. I need to also replace the rollers. not sure about remove all the mechanisms. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | The glass is attached to a bracket. The bracket is attached to the regulator (2 screws). From the inside, you have to roll the regulator up / or down to be able to access the attaching points. Not sure if my description of regulator is what you refer to as rollers, but I can't think of what else it might be. Are you missing the bracket? Haven't removed the regulator myself, but it has to come out of the access holes in the interior door. I suppose things could go in backwards and that might not allow holes to line up. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | longboarder - sounds like what you've got wrong is what Hambone mentions, the channel that the rollers go into needs to be on the rollers before the glass is put in the door, then the glass sash is attached to that channel inside the door
Bill | | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | Thanks guys, have the channel on the glass in the door. Can't seem to get the window on the roll up mechanism? to slide into the window. Do I slide window onto the arms, then slide in the vent window.Vent window goes in easier with window in door but not in the tracks. But can't get them together. Trying figure out which order things go in?
Brett | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | repeat - the channel is put on the rollers before any glass is put it - the widow glass and vent assembly go in at the same time, then the window glass lower sash is attached to the channel that's already on the rollers
Bill | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | longboarder You may try looking at the following link https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=594497&page=1At one time I had a PowerPoint and Word document where I detailed putting the doors together. Last year my computer died and I no longer have them. However I sent the documents to several bolters. Maybe they still have a copy. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Hey Brett. I sent you a PM, if you want me to walk you through the process, over the phone.
| | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | Hey thanks everyone, I'll give Tony a call it will simplify things.
Brett
