5 members (55shaker, Gdads51, Ponchogl, DadsFirstPickup, stlcardinalsguy), 125 guests, and 1 robot.
Topics128,054
Posts1,055,782
I recently bought a '51 Chevy 3100. It was registered using the engine serial number which is on the title. I researched the truck serial number (5JP-E17984)located on the door post and discovered it was built during May 1951 in Kansas City, MO. I'd like to decode any information from the engine serial number which I believe is JBA636607 which is located on the passenger side of the block. I'd like to find out if the engine was the original in the truck.
In the "Inline 6 engines" factory casting number & code book it shows JBA as 1951 3100 truck 216CID with 92hp manual transmission. Hope that helps some.
-Paul
Okay. That's interesting. I thought it was the 235.Thank you.
J- model year = 1951
B- Regular
A- made in Flint Mich.
6 cyl. 216 cid. 92 HP. 6.6:1 comp.ratio 1 bc carb.
Pete
Thanks all! Big help!
