| | | Forums66 Topics128,062 Posts1,055,851 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 8 New Guy | | New Guy Joined: Sep 2012 Posts: 8 | I recently bought a '51 Chevy 3100. It was registered using the engine serial number which is on the title. I researched the truck serial number (5JP-E17984)located on the door post and discovered it was built during May 1951 in Kansas City, MO. I'd like to decode any information from the engine serial number which I believe is JBA636607 which is located on the passenger side of the block. I'd like to find out if the engine was the original in the truck. | | | | | Joined: Jul 2011 Posts: 24 New Guy | | New Guy Joined: Jul 2011 Posts: 24 | In the "Inline 6 engines" factory casting number & code book it shows JBA as 1951 3100 truck 216CID with 92hp manual transmission. Hope that helps some.
Thanks, -Paul | | | | | Joined: Sep 2012 Posts: 8 New Guy | | New Guy Joined: Sep 2012 Posts: 8 | Okay. That's interesting. I thought it was the 235.Thank you. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | J- model year = 1951 B- Regular A- made in Flint Mich.
6 cyl. 216 cid. 92 HP. 6.6:1 comp.ratio 1 bc carb.
Pete
| | | | | Joined: Sep 2012 Posts: 8 New Guy | | New Guy Joined: Sep 2012 Posts: 8 | | | |
