1 members (Shade Baby),
58
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Just noticed a click sound every time I push down on my brake pedal. The brakes are working OK but occasionally drag when hot after braking. No leaks anywhere. No grinding noise or pulling. The master cylinder was replaced a few years back.
Not sure if there's a problem coming.?? | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Assuming it is not the master cylinder, you could check the stop lamp switch. Easy things first. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Also check your spring attached to the pedal, it could be out of place.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Two easy things to look at. Hopefully its something simple and/or cheap to fix. Its weird how after you've owned a truck for a time you develop an ear for hearing any out of the ordinary noise.
Thanks. | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Sometimes, my brake pedal rubs against the sheet metal in the floor. Likely due to worn out cab mounts. Sometimes I get out of the truck to find that my brake lights are on. Just something to look at.
1956 Chevy 3200
