0 members (), 95 guests, and 7 robots.
Topics128,271
Posts1,058,313
Members48,485
#883365 09/17/2012 9:21 PM
Just noticed a click sound every time I push down on my brake pedal. The brakes are working OK but occasionally drag when hot after braking. No leaks anywhere. No grinding noise or pulling. The master cylinder was replaced a few years back.
Not sure if there's a problem coming.??
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
MarkT #883437 09/18/2012 8:38 AM
Assuming it is not the master cylinder, you could check the stop lamp switch. Easy things first.
Donsz #883453 09/18/2012 10:41 AM
ODSS Lawman
ODSS Lawman
Also check your spring attached to the pedal, it could be out of place.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #883517 09/18/2012 5:59 PM
Two easy things to look at. Hopefully its something simple and/or cheap to fix. Its weird how after you've owned a truck for a time you develop an ear for hearing any out of the ordinary noise.
Thanks.
MarkT #883565 09/18/2012 9:14 PM
Sometimes, my brake pedal rubs against the sheet metal in the floor. Likely due to worn out cab mounts. Sometimes I get out of the truck to find that my brake lights are on. Just something to look at.
1956 Chevy 3200
