| | | Forums66 Topics128,013 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Can anyone tell me if the square heater cores sold by the usual vendors will fit inside the stock round housing? The original round heater core for my truck is shot and I haven't been able to find a replacement. Seems like a stretch that the square replacements would fit in the round housing but I just thought I'd ask.
1956 Chevy 3200
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no it won't fit - the round one is available, but spendyBill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well, try to get the soldering technique a little cleaner  you could look for another TF heater version with the rectangle core, like a deluxe - might find a used one that already has a good core Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I actually started to make one of those as a replacement but put it on a back burner. I'll give my soldered up original another go now that I've tested it with 20 lbs psi. It was a good idea but I think the copper line is too large. There isn't enough room to solder and align the fins. If/when I try it again I'd use a size or two smaller dia. line and be careful aligning the holes in the fins so things fit snug but free enough to slide around the two lines. Those were the problem areas I found. Its time consuming but it leaves your wallet a LOT fatter.+
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | What size copper lines did you use? Do you have pictures?
1956 Chevy 3200
