4 members (Shaffer's1950, Oswald, JJs55210, 1 invisible), 41 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#882722 09/14/2012 9:56 PM
Can anyone tell me if the square heater cores sold by the usual vendors will fit inside the stock round housing? The original round heater core for my truck is shot and I haven't been able to find a replacement. Seems like a stretch that the square replacements would fit in the round housing but I just thought I'd ask.
1956 Chevy 3200
no it won't fit - the round one is available, but spendy
Flxible #882791 09/15/2012 7:21 AM
Boy, you said it. This is starting to look more attractive: http://www.damtp.cam.ac.uk/user/cm214/bi-lunar/heater.html
1956 Chevy 3200
well, try to get the soldering technique a little cleaner grin
you could look for another TF heater version with the rectangle core, like a deluxe - might find a used one that already has a good core
I actually started to make one of those as a replacement but put it on a back burner. I'll give my soldered up original another go now that I've tested it with 20 lbs psi. It was a good idea but I think the copper line is too large. There isn't enough room to solder and align the fins. If/when I try it again I'd use a size or two smaller dia. line and be careful aligning the holes in the fins so things fit snug but free enough to slide around the two lines.
Those were the problem areas I found. Its time consuming but it leaves your wallet a LOT fatter.+
Give me ambiguity
or give me something else
CASO #882849 09/15/2012 12:23 PM
What size copper lines did you use? Do you have pictures?
1956 Chevy 3200
Moderated by  ndkid275, Phak1
