5 members (klhansen, Bill Hanlon, moparguy, Otto Skorzeny, RaNfLaS), 320 guests, and 3 robots.
Topics128,162
Posts1,057,059
Members48,463
#882666 09/14/2012 6:20 PM
When I'm not tinkering with stovebolts I'm building rifles, either from military surplus bolt actions like WW II Mausers, or commercial rigs like Remington, Ruger, or Savage. Way back in the dark ages when I got started, I built my own barrel-holding vise and action wrench to help change barrels. The wrench worked well, but I never was really satisfied with the way the barrel vise performed. Now, 30 years later, I've upgraded- - - -it's another home-made rig, one which can also be used for pressing pistons on and off connecting rods. That's a 12-ton jack, which should give me plenty of clamping force on a barrel while I put some serious torque on the action assembly!
http://www.hunt101.com/data/500/100_5601.JPG
http://www.hunt101.com/data/500/100_5602.JPG
Looks like its built like a tank. Good job!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Glad to see you're finally posting some pictures of your projects Jerry. We’ve
heard a lot about them over the years but never get to see them. Remember that
saying that the Pharaoh’s coined? “A picture is worth a thousand words.”
That press looks like it will be a handy addition to your shop, whether you’re
wearing your mechanics hat or your gunsmith hat. .
Me dear old Pop passed away thirty years ago but I acquired a lot of his shop at
the time to supplement my own. One of the things that he made for his shop and
that I use a lot is his version of the "mini-press".
http://www.pbase.com/dennygraham/image/147787953
It's just a length of 3"-5lb A-36 channel iron with some holes drilled thru it and a
small bottle jack. He mounted a small bottle jack he had laying around the shop
inverted, drilled a hole in the base into the sump and added a small reservoir for
the fluid.
I also built a full size press using 4" channel some years later.
We drilled (mill cutter) the holes in a Bridgeport Milling machine to keep the
table square but with care you could drill them with a twist drill.
Denny Graham
Somewhere north of Sandwich, IL
Denny G
Sandwich, IL
Moderated by  MNSmith
