0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Am trying to tighten up my steering as per the Tech Tip entitled "Saginaw Steering Sector Adjustment". For the life of me I can't get the Worm Gear Locknut to loosen up. It just won't budge!! Is there a special tool or a trick needed to get it to loosen up? I've tried everything in my toolbox except oxy-acetylene..... Needs adjustment bad as there is no drag at all on the steering wheel when the worm bearings are loosened up. Truck wanders a lot when on the road. The truck is a 55 series II long wheelbase. Many Thanks | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I'd say the oxy-acetylene might be the next choice, but considering. Try some penetrating oil. Gibbs, Kroil, PB blaster, there is even a recipe to make you own here on the board. Let it sit overnight, use a 6 point socket and a cheater bar with restraint, the object is to put as much pressure on the nut with the least effort. If that doesn't work gently heat with a propane torch, more penetrant, and let sit again. Try again, if it doesn't move, then try tightening it, you just want the the nut to move as soon as it does, back off. Try to remove it again. If that doesn't work. the oxy-acetylene maybe your only choice, I sure hope not.
Good Luck
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | What size is the lock nut? I'd be leary about cooking the steering box with a torch...  Jeff | | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Locknut is 2 1/4". I agree, torching it doesn't seem like the best idea. Got a new 3/4" drive 6 point socket today. Will try again. Suspect the the lock nut hasn't been loosened since assembly back in 55. Thanks | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I used a pipe wrench. But, the steering box was clamped in a vice on the work bench. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | First, are you sure you want to mess with the worm adjustment? I work on a lot of steering boxes and I doubt you will remove any slop in the box with this adjustment. If the play can not be removed with the sector/pitman shaft adjustment you most likely need new pitman shaft bushings, or possibly a pitman shaft also.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Hello All, Finally got it all apart yesterday. Everything is OK and the steering box internals are all in great shape. Will proceed with the adjustment as outlined in the service manual. Am optimistic that this will reduce the wandering. NEED INFO ON THE DRAG LINK. MINE HAS VERY "NOTCHY" BALL JOINTS. THEY ARE STILL TIGHT AND HOLD GREASE BUT DO NOT ARTICULATE SMOOTHLY AND ONE IS STIFFER THAN THE OTHER. HOW WILL THIS AFFECT MY STEERING? SHOULD I REPLACE THE DRAG LINK? NEVER NOTICED ANYTHING WHEN DRIVING. Many Thanks to all who responded. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | You could get a kit to rebuild the drag link, new cups springs etc.
Kurt | | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Kurt, Who sells the kit you mentioned? Thanks | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Here is a link to Chevy of the 40's rebuild kit. I'm sure the other vendors carry it also. Drag link rebuild kit Kurt | | |
