3 members (Cosmo, LAROKE, 1 invisible),
51
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88208 03/07/2003 2:29 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Does anyone know what vehicles and/or engine sizes I could get a donor (boneyard) HEI from for my 235? Are they a direct fit or are Mods needed?Thanks | | |
#88209 03/07/2003 9:13 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The later 250/292 HEI will fit, but there are a few modifications involved. There is a tech tip around here somewhere. Try an archive search. | | |
#88210 03/07/2003 9:21 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | HEI's were introduced on the 75 model pickup six. There are some earlier threads on how to mod one. Around here, they're getting scarce, last price I saw was $65. For around $80, you can buy a Pertronix to go in your distributor.
Fred 52 3600 69 C-10
#88211 03/07/2003 9:35 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 |
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#88212 03/07/2003 10:07 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Chip, have you figured out how to install that disrtibutorless crank-triggered ignition system yet
#88213 03/07/2003 10:57 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Yeah, that'll work. Its turning the oil pump that seems to be the problem. :rolleyes:
#88214 03/07/2003 11:40 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Plumb in one of those high-performance belt drive ones they use in race-cars
#88215 03/08/2003 12:03 AM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | A dry-sump 235. ROFLMAO.
Bullnose- all kidding aside, I'm in the middle of trouble shooting a very serious and complicated problem with my 235 that has something to do with my use of a modified HEI from a chevy 2.8 liter V-6. Do a search and find my old threads, as you'll find a vast discussion of distributor options, problems & measurements dealing with HEI distributors and hopped-up 235s.
good luck
chip
#88216 03/08/2003 1:11 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Thanks for the input guys. I thought the pertronix unit was more expensive. Is the Pertronix easy to install, reliable, or as they say proven? Chip, I read some of your threads. Did you ever figure out the prob with your distributor? | | |
#88217 03/08/2003 2:00 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I dropped a dual point kit into mine that I bought on eBay last year for $10. It still uses points but it has much more oomph and the points last much longer because it uses one set to open and one set to close. All I had to do was change the breaker plate and add the new points. The condensor gets moved outside the distributor > I didn't even have to pull it out, it's a 4 screw job.
#88218 03/21/2003 4:10 AM | Joined: Mar 2003 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2003 Posts: 45 | The Pertronix units are simple easy to install,reliable and easy to revert back to points on the side of the road if needed,just save the old parts.  They are THE #1 ignition upgrade in the material handling business.One of the downsides is that you don't have the advantage of the fat distributor cap if you are running a high output coil.  An MSD-6A is a worthwile addition if you have 12 volts,negative ground.  | | |
