1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#88208 03/07/2003 2:29 PM
Does anyone know what vehicles and/or engine sizes I could get a donor (boneyard) HEI from for my 235? Are they a direct fit or are Mods needed?Thanks
#88209 03/07/2003 9:13 PM
The later 250/292 HEI will fit, but there are a few modifications involved. There is a tech tip around here somewhere. Try an archive search.
1954 GMC De Luxe COE
#88210 03/07/2003 9:21 PM
HEI's were introduced on the 75 model pickup six. There are some earlier threads on how to mod one. Around here, they're getting scarce, last price I saw was $65. For around $80, you can buy a Pertronix to go in your distributor.
Fred
52 3600
69 C-10
#88211 03/07/2003 9:35 PM
No Comment. :o
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#88212 03/07/2003 10:07 PM
Chip, have you figured out how to install that disrtibutorless crank-triggered ignition system yet grin
#88213 03/07/2003 10:57 PM
Yeah, that'll work. Its turning the oil pump that seems to be the problem. :rolleyes:
#88214 03/07/2003 11:40 PM
Plumb in one of those high-performance belt drive ones they use in race-cars cool
#88215 03/08/2003 12:03 AM
A dry-sump 235. ROFLMAO.
Bullnose- all kidding aside, I'm in the middle of trouble shooting a very serious and complicated problem with my 235 that has something to do with my use of a modified HEI from a chevy 2.8 liter V-6. Do a search and find my old threads, as you'll find a vast discussion of distributor options, problems & measurements dealing with HEI distributors and hopped-up 235s.
good luck
chip
#88216 03/08/2003 1:11 AM
Thanks for the input guys. I thought the pertronix unit was more expensive. Is the Pertronix easy to install, reliable, or as they say proven? Chip, I read some of your threads. Did you ever figure out the prob with your distributor?
#88217 03/08/2003 2:00 AM
I dropped a dual point kit into mine that I bought on eBay last year for $10. It still uses points but it has much more oomph and the points last much longer because it uses one set to open and one set to close. All I had to do was change the breaker plate and add the new points. The condensor gets moved outside the distributor > I didn't even have to pull it out, it's a 4 screw job.
Paint & Body Shop moderator
#88218 03/21/2003 4:10 AM
The Pertronix units are simple easy to install,reliable and easy to revert back to points on the side of the road if needed,just save the old parts. eek They are THE #1 ignition upgrade in the material handling business.One of the downsides is that you don't have the advantage of the fat distributor cap if you are running a high output coil. frown An MSD-6A is a worthwile addition if you have 12 volts,negative ground. cool
