0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88166 03/21/2003 5:04 AM | Joined: Jun 2001 Posts: 1 Member | | Member Joined: Jun 2001 Posts: 1 | I've recently started to blow the dash/tail light fuse in my 71 c-10 (power nothing/ bare bones) I'm thinking it's the headlight switch itself as the fuse only goes when the switch is on. I've also had a loose wire on my driver's headlight, but I've had that for 2 years and I've never blown a fuse. Now a fuse lasts a minute tops. Also I had the flashers on after the tail light fuse blew, and it surged (causing the dash lights to flicker) and then the flasher went out. So is it the headlight, light switch, or am I chasing more wires?
- C | | |
#88167 03/21/2003 5:25 AM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | There's something systemic going on; I would look for a bad ground to the dash panel on the lighting circuit. | | |
#88168 03/21/2003 7:05 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I agree with the Hedge - start looking for bad grounds or worn wires that could be causing a short. The '84 S-10 Blazer that I drove when I first turned 16 (with GM's worst engine of all time, the 2.8L V6) had a transient short in the turn signals, drove me nuts until it got me rear-ended by a guy with failing brakes. After that, the POS left my possession. If it had been anything worth having around, I would have worked harder to find the problem. | | |
#88169 03/21/2003 9:17 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Inspect the wires going from the cab , back to the tail-lights. I usually find the problem there with the dash/tail lights
#88170 03/21/2003 4:05 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Try soldering a tail lamp bulb across a blown fuse. Then wiggle the wires around under the dash and under the box etc, while watching the light for changes in brightness, more than likely someware a wire has been chafed or pinched. Found a wire pinched in the lock for the bench seat slide once. | | |
#88171 03/22/2003 2:44 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | If you still have the spare tire under the truck check the wire that runs along the frame,when I changed a tire in the 67 C-20 I had years ago the carrier bolt pinched the wires and I had the same problem as you describe | | |
#88172 03/22/2003 2:50 AM | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | had a couple of those trucks myself when I had that prob it was the flat ribbon wire from fire wall to tail lamp plug. usually burnt on exaust pipes or rubbed on hanger. | | |
#88173 03/24/2003 8:43 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | I go for rubbing wire on frame to lights also. ON older trucks, the body mount goes bad, cab settles and rubs wire between it and frame and shorts. Had that on my 54. I usually run a trailer wiring harness back to lights and buy some of that black corrugated split harness protector to put it in. That way you can wire-tie it to frame holes and x-members and not rub wires.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#88174 03/24/2003 8:45 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Forgot to say that the fuse for dash lights used to be for tails also, so may show problem there in dash and not be the problem area at all. Don't know how long they did that or if the still do.
