1 members (TexasA&M48Truck), 67 guests, and 3 robots.
Topics128,082
Posts1,055,964
Members48,430
#88166 03/21/2003 5:04 AM
7
7 Offline
I've recently started to blow the dash/tail light fuse in my 71 c-10 (power nothing/ bare bones) I'm thinking it's the headlight switch itself as the fuse only goes when the switch is on. I've also had a loose wire on my driver's headlight, but I've had that for 2 years and I've never blown a fuse. Now a fuse lasts a minute tops. Also I had the flashers on after the tail light fuse blew, and it surged (causing the dash lights to flicker) and then the flasher went out. So is it the headlight, light switch, or am I chasing more wires?
- C
#88167 03/21/2003 5:25 AM
There's something systemic going on; I would look for a bad ground to the dash panel on the lighting circuit.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#88168 03/21/2003 7:05 AM
I agree with the Hedge - start looking for bad grounds or worn wires that could be causing a short. The '84 S-10 Blazer that I drove when I first turned 16 (with GM's worst engine of all time, the 2.8L V6) had a transient short in the turn signals, drove me nuts until it got me rear-ended by a guy with failing brakes. After that, the POS left my possession. If it had been anything worth having around, I would have worked harder to find the problem.
1954 GMC De Luxe COE
#88169 03/21/2003 9:17 AM
Inspect the wires going from the cab , back to the tail-lights. I usually find the problem there with the dash/tail lights
#88170 03/21/2003 4:05 PM
Try soldering a tail lamp bulb across a blown fuse. Then wiggle the wires around under the dash and under the box etc, while watching the light for changes in brightness, more than likely someware a wire has been chafed or pinched. Found a wire pinched in the lock for the bench seat slide once.
#88171 03/22/2003 2:44 AM
If you still have the spare tire under the truck check the wire that runs along the frame,when I changed a tire in the 67 C-20 I had years ago the carrier bolt pinched the wires and I had the same problem as you describe
#88172 03/22/2003 2:50 AM
Junior Member
Junior Member
had a couple of those trucks myself when I had that prob it was the flat ribbon wire from fire wall to tail lamp plug. usually burnt on exaust pipes or rubbed on hanger.
#88173 03/24/2003 8:43 PM
I go for rubbing wire on frame to lights also. ON older trucks, the body mount goes bad, cab settles and rubs wire between it and frame and shorts. Had that on my 54. I usually run a trailer wiring harness back to lights and buy some of that black corrugated split harness protector to put it in. That way you can wire-tie it to frame holes and x-members and not rub wires.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#88174 03/24/2003 8:45 PM
Forgot to say that the fuse for dash lights used to be for tails also, so may show problem there in dash and not be the problem area at all. Don't know how long they did that or if the still do.
G.L. Grumpy's
Old Iron Ranch
