9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible), 43 guests, and 1 robot.
Topics128,090
Posts1,056,016
Members48,430
At one time someone posted the correct number of classification lights that go on the truck cab roof to denote the trucks size/weight . I looked in the "search" area but can't find the post . Anyone have that info ? I just got a '53 Chevy 1 1/2 ton wrecker but it has no roof lights and I want to put the correct number of them on it . Thanks in advance .
Ed H
never heard of "classification lights", but over a certain size [depending on the jurisdiction, usually based on width] there's normally 3 in the center a few inches apart called marker lights to indicate height, and one as near to the widest outside points as possible, called clearance lights - ones at the front are always yellow now but the front clearance lights at one time were green - ones at the back are always red .... you should check the Kansas MV code, it'll be specified
I have a 53 die cast tow wrecker, it only has one red one.
Redryder pix
My Hotrod
There is no correct number, depending on what you mean by "correct".
I will be putting none on my 54/55 GMC 2-ton
That is the way it came from the factory.
Thanks for the input .
Ed H
Riding in the Passing Lane
I like the looks of them. Like on my 70.
1972 Chevy c10 Cheyenne Super
Federal commercial vehicle regs:
say that any truck over 80" wide needs two clearance lights (at front corners of roof) and three identification lights (front center of roof 6"-12" apart). I have seen AD series trucks with three lights total, one at each corner and one at the center. I think at one time they used three for the widest trucks and one for "in between?" I have also seen pictures of green lenses used on some of these trucks instead of amber.
Those regs are for vehicles manufactured after 1968.
It would be interesting to see the 1950s regs.
"All commercial motor vehicles manufactured on or after December 25, 1968, must, at a minimum, meet the applicable requirements of 49 CFR 571.108 (FMVSS No. 108) in effect at the time of manufacture of the vehicle. Commercial motor vehicles manufactured before December 25, 1968, must, at a minimum, meet the requirements of subpart B of part 393 in effect at the time of mnufacture.
