Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (mo2cyl, panic), 59 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#881175 09/08/2012 9:37 PM
Im am still in the process of replacing my brakes and was wondering what everyone does about the maser cylinder? The original one looks to be in good shape, but I have had people tell me I should look at dual cylinder models for safety.
I was planning on re-building the original one, but should I be looking at other options?
safety is in the driving more than the technology, if you're not planning on a lot of high speed freeway time stock is fine, they got the ol truck thru the last 60 years wink
Flxible #881188 09/08/2012 10:20 PM
I agree with red48, I went back with stock type.
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
Duwop #881191 09/08/2012 10:33 PM
Thanks, sounds like I will go with my original plan.
Riding in the Passing Lane
I agree on keeping the original but o-haul it & replace all the steel lines & hoses. Have the emerg. brake working good.
1972 Chevy c10 Cheyenne Super
I just finished replacing all the steel lines (literally 10 minutes ago). Now I am waiting on is wheel cylinder kits, hoses, etc to show up.
How forgiving are the lines with a double flare? I made about 10 practice flares before the real ones and they look similar to the ones I pulled off the truck. This is my first experience with them so I am not positive what to look for.
Making a good double flare is crucial. If you're not having any luck you may need a better flare tool kit.
Some tips are:
Be sure the tube end is square, use a file to true it up if necessary.
Debur the inside of the tube with a little countersink, just enough to make a little bevel about 1/3 the wall thickness.
With a small file file a similar bevel on the outside.
Use a drop of oil on the end.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Moderated by  Dusty53
