0 members (),
52
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | Im am still in the process of replacing my brakes and was wondering what everyone does about the maser cylinder? The original one looks to be in good shape, but I have had people tell me I should look at dual cylinder models for safety.
I was planning on re-building the original one, but should I be looking at other options? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | safety is in the driving more than the technology, if you're not planning on a lot of high speed freeway time stock is fine, they got the ol truck thru the last 60 years  Bill | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | I agree with red48, I went back with stock type. | | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | Thanks, sounds like I will go with my original plan. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree on keeping the original but o-haul it & replace all the steel lines & hoses. Have the emerg. brake working good. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | I just finished replacing all the steel lines (literally 10 minutes ago). Now I am waiting on is wheel cylinder kits, hoses, etc to show up.
How forgiving are the lines with a double flare? I made about 10 practice flares before the real ones and they look similar to the ones I pulled off the truck. This is my first experience with them so I am not positive what to look for. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Making a good double flare is crucial. If you're not having any luck you may need a better flare tool kit.
Some tips are: Be sure the tube end is square, use a file to true it up if necessary. Debur the inside of the tube with a little countersink, just enough to make a little bevel about 1/3 the wall thickness. With a small file file a similar bevel on the outside. Use a drop of oil on the end.
Grigg | | |
