3 members (WICruiser, 2 invisible), 142 guests, and 4 robots.
Topics128,109
Posts1,056,269
Members48,439
#8808 08/09/2002 11:39 PM
Hello all,
I was wondering what oil pressure a small block chevy V-8 should run at hot idle. I have a rebuilt 283 with 40K miles and it only runs about 7.5 psi when good and warm and idling in traffic. Thanks...Tom.
#8809 08/10/2002 1:48 AM
Have you checked to verify the pressure with another known good oil pressure guage?
It can run on that pressure,but I would feel safer if it were around 15 to 20psi +
#8810 08/10/2002 3:23 AM
my rebuilt 283 w/ under 5000 mi and a high pressure pump, puts out ~30psi [center of stock gauge] at hot idle, and pegs the gauge when over idle cold - nearly so when warmed up. I'd verify that pressure like mechainiac sez, and if it's real - change the pump. might be usin too lite oil too.
