0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#8808 08/09/2002 11:39 PM | Joined: Jun 2002 Posts: 21 Member | | Member Joined: Jun 2002 Posts: 21 | Hello all,
I was wondering what oil pressure a small block chevy V-8 should run at hot idle. I have a rebuilt 283 with 40K miles and it only runs about 7.5 psi when good and warm and idling in traffic. Thanks...Tom. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Have you checked to verify the pressure with another known good oil pressure guage? It can run on that pressure,but I would feel safer if it were around 15 to 20psi +
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | my rebuilt 283 w/ under 5000 mi and a high pressure pump, puts out ~30psi [center of stock gauge] at hot idle, and pegs the gauge when over idle cold - nearly so when warmed up. I'd verify that pressure like mechainiac sez, and if it's real - change the pump. might be usin too lite oil too.
Bill | | |
