3 members (Phak1, Otto Skorzeny, TexasA&M48Truck), 110 guests, and 1 robot.
Topics128,092
Posts1,056,040
Members48,433
#879939 09/03/2012 12:50 PM
V
V Offline
Anyone out there try this on a stock 235? Looking for input from someone smarter than me who may have tried it and/or know where to get one that fits/works. Thanks
'57 3200
H Online: Content
Why bother? It's just a scam to separate a gullible customer from his money, no matter what kind of engine it's installed on.
Carburetion specialist
Jerry, I must respectfully disagree. While I have never used one on a 235, I did fabricate one to place on a 454 in a motorhome. There was a measurable difference in fuel economy (something like 6 percent). Not saying it would work in all cases, but it did on the motorhome.
I removed the original snorkel and cut a hole for a rectangular dryer vent hose to fit the air cleaner. I then cut a hole in the radiator support, and ran the dryer hose to the outside air. I then covered the hole with mesh to keep out the paper wasps and grasshoppers. More time-consuming than costly.
Jon.
The Carburetor Shop
H Online: Content
Jon, I can see the advantage to that type of modification, particularly in the summertime whem underhood temps can get extreme. Most of the time, the term "cold air intake" is a buzzword for one of the ridiculous intake systems like the K&N, that's just a half-donkeyed low-restriction "filter" that lets in enough dirt to wear an engine out in the name of "better breathing".
Anytime you can can get fresh air into a engine, it will run better. If you are having issues with under hood heat, then it will help a lot, but your engine is working normal, and heat is controlled, then you may not see any gains. If you do go this route, be sure to insulate the air tube going to the carb, or it will just supply heated air. You will never know till you try it, so I say go for it and let use know what happens.
Joe
1 Offline
I have it on several stovebolt sixes and all seemed to run better when I did this. The one in my '32 Chevy really came alive with the intake inducting cool air.
Normbc9
