8 members (Bill Hanlon, Jon G, 55shaker, Otto Skorzeny, HandyAndy, UtahYork, DadsFirstPickup, Hotrod Lincoln),
78
Mod | | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 91 | Well I finally got around to wiring up the turn signals on my 46. I used a 3-wire flasher as per the signal switch's instructions. As I do not have the actual lights on the truck yet I simply grounded my test lamp and stuck it to the various wires to make sure I didn't screw up. The test lamp lights up when I want it to but nothing flashes. It's just a steady light.
So, do I have a faulty flasher or do the turn signal lamps have to be in place for my blinkers to blink? | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Your test light is not enough resistance to make the flasher work. You need the bulbs!
Les | | | | | Joined: Jul 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 91 | OK. I kinda figured that was what was going on. Thanks bub. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | 'Roadmarks', Are you sure the problem is "not enough resistance" or to much resistance and not enough current?
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The flasher operates by the heat produced by the load of the bulbs. The heat bends a tab to break contact, then cools, recontacts and reheats. Not enough load = not enough heat. | | |
