1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#879787 09/02/2012 8:06 PM
Well I finally got around to wiring up the turn signals on my 46. I used a 3-wire flasher as per the signal switch's instructions. As I do not have the actual lights on the truck yet I simply grounded my test lamp and stuck it to the various wires to make sure I didn't screw up. The test lamp lights up when I want it to but nothing flashes. It's just a steady light.
So, do I have a faulty flasher or do the turn signal lamps have to be in place for my blinkers to blink?
Your test light is not enough resistance to make the flasher work. You need the bulbs!
Les
OK. I kinda figured that was what was going on. Thanks bub.
'Roadmarks', Are you sure the problem is "not enough resistance" or to much resistance and not enough current?
The flasher operates by the heat produced by the load of the bulbs. The heat bends a tab to break contact, then cools, recontacts and reheats. Not enough load = not enough heat.
