5 members (jmoore, Bill Hanlon, 3B, 54farmtruck, Phak1), 95 guests, and 1 robot.
Topics128,188
Posts1,057,329
Members48,469
I play with antique fire trucks and I just pulled these gauges out of an old fire truck. The fire truck was a huge American LaFrance from the 1960's, but these factory original gauges certainly look like 1947 - 1953 gauges to me. Note the higher oil pressure and amp gauge. The tachomter seems to made by the same manufacturer! I wonder if any 1947-53 Chevrolet/GMC trucks ever used a tach?
[IMG]http://i1122.photobucket.com/albums/l523/cjasonbarnett/CIMG8724.jpg[/IMG]
[IMG]http://i1122.photobucket.com/albums/l523/cjasonbarnett/CIMG8727.jpg[/IMG]
[IMG]http://i1122.photobucket.com/albums/l523/cjasonbarnett/CIMG8725.jpg[/IMG]
[IMG]http://i1122.photobucket.com/albums/l523/cjasonbarnett/CIMG8726.jpg[/IMG]
The aviation artist guy in Houston that loves old trucks even more than planes. www.jasonbarnettartist.com
I think that the big GMC trucks with diesels used those
I heard they did, in the larger trucks, sure would be a generous gesture if you were to let me have that there tach, ya got. (I have been looking for a while)
Where did the speedometer cables go to? Wondering why the miles are so far apart. I'm guessing the tach ran off the PTO somehow, that would explain the difference in the odometer readings.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
The motor miles on the tach are different than the miles on the speedometer because many of the pumps were run while the transmission was in neutral.
A few fire trucks ran their pumps while the transmission was in gear. Even then the speedometer cable may have been farther back in the drive line so that it didn't work while the pump was engaged so they added motor miles to the tach to keep up with how much mileage the engine actually had.
Looks to me like this tach probably is a speedometer, except it has a different scale on the face. So I think you could probably make one pretty easily using a speedometer. The issue would be where to hook it up. I think they were usually connected to the distributor which had a takeoff for the tach.
Kurt
Most of the gasoline powered fire trucks were dual ignition and have a place on the distributor for a tachometer. The speedometer was attached to the PUMP transmission. When the truck is pumping, the transmission is in high gear unless it is an overdrive trans, then it is pumped with the trans in 1 to 1 gear. There is a large PUMP transmission that is linked in behind the conventional trans. To engage the pump, the pump transmission is engaged and it throws the drive shaft that goes to the rear axle into neutral and it turns a short drive shaft that turns the pump. While the truck is pumping, the speedometer is at idle, but the tachometer is still going. The engines are running pretty hard when the truck is pumping. Never judge a pumper truck by its road miles!
Its been a loooong time but I remember the question of the "AD" guages being in a LaFrance firetruck....yep sure nuff.
