1 members (homer52), 72 guests, and 1 robot.
Topics128,049
Posts1,055,638
#878903 08/29/2012 10:00 PM
Y
Y Offline
I installed the new wire loom in my 53 burb, with 54 235. Now I've got couple of questions, the dash brace located between the insturment clusters has a hole with a rubber grommet in it, and I think it's where the horn wire goes? The other issue is I have a 12 volt battery, 6 volt generator, 12 volt coil, and 6 volt starter, so whats the end result-6 volt or 12 volt? I do have the resister on the coil, and everything seems to work OK. Thanks, Phil
Other than the coil all electrical components look to be original? Haven't driven it that much, just let it sit and idle, seems to stay charged.
What kind of voltage regulator do you have?
How long have you been charging a 12v battery with a 6v generator?
tclederman #878988 08/30/2012 10:45 AM
he isn't charging a 12v battery with a 6v generator!
tomctomc #879219 08/31/2012 6:29 AM
ohwell
Why the mix of 6 and 12v? Why not just switch everything to 12v?
Using a 6v starter in a 12v system (with a 6v flywheel) is commonly done with minimal problems (in a quick starting system).
H Online: Content
It's possible to crank a 6V generator/regulator up to 12 volts for a short time, but it's not a good idea. More likely, the battery just hasn't run down enough to fail to start the engine yet, and the generator is doing nothing. Unless the regulator has been readjusted to take the higher voltage battery into account, I can't imagine the battery getting charged much, if any.
k10 Offline
Get a 12v 1-wire alternator and replace the generator and voltage regulator. Get some threaded rod and a tube and fab up a new support for the alternator. You'll need a new upper adjustable bracket for an alternator available at any parts store for cheap. (if I recall,you have a straight one and you need a curved one so you can adjust the tension)I believe that you also need to reverse the wires on your voltmeter and you're almost done. Don't forget to change ALL of the bulbs in the truck to 12 volt. And TomC, yes he IS attempting to charge a 12v batt with a 6v gen. And it ain't gonna work. dance
k10 #879409 08/31/2012 11:10 PM
Assuming you have a 6 volt VR, and generator Just get a 6 volt battery and coil. Done.
Kurt
