7 members (Charles in CA, 55shaker, Gray_Ghost, Guitplayer, Wally / Montana, JW51, Otto Skorzeny),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,724 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Hey bolters; I just finished putting new brakelines on my 1950 3800, all the way around and had the front 2 wheel cylinders replaced, the rear wheel cylinders rebuilt. After bleeding them I'm noticing just a little bit of brakefluid where the wheel cylinder meets that little brass junction block. I re-used those little brass washers that were on it originally, but still seeing some moisture at all 4 wheels. its not alot, just a smudge over the last day. Any suggestions? Should there be a little rubber seal between the junction and cylinder as well?
Thanks - Carmental | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Replace the crush washers.
Bruce | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is pretty well your only choice. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yep, those copper sealing washers are a one time use deal.
...That said on several occasions when in a bind I've annealed them, flattened both sides with fine sand paper on a true flat surface, and reused them.. Not the best idea on something as critical as your brake system.
Your local auto parts store should have them in stock.
Grigg | | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | I'll check into them, that makes perfect sense that they would be the cause. Thanks for the info guys.
Carmental | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | To prevent getting bitched at, I'm not going to say it is a good idea or a bad idea, but I have seen dozens of times where folks used more than one copper crush washer without any leaking or brake issues.
Jeff | | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Like my bartender says: If one doesn't do the job, you can always try another. I'll give that a try if the new one's don't do the job.
Carmental | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'd try to get the job done with one washer. The mating surfaces on the wheel cylinder and the bolt have what's called a "phonographic finish" which is designed to bite into the copper and create a better seal than a plain dead flat and smooth surface will. When using 2 washers you would have a less than ideal seal between the two washers.
Grigg | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Actually, (WARNING: useless information follows), the rings on my brake cylinder surfaces (master and wheel) are Concentric Serrated Finish (I think), which is not "phonographic" (as in Stock Finish and and in Spiral Serrated Finish).
Clearly, I am avoiding going out to the garage to work on my trucks?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think Tim's right... similar idea and I still wouldn't stack sealing washers. Now get out there and work on your truck  Grigg | | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Ok ok! I got out there and worked on the truck. A shiny set of new crush washers, a quick bleed (after I scraped my knuckles), then I bled the brakes and viola! No more leaks.
Now all I have left to do is.... Build the truck bed fix the sheet metal on the truck visit cash machine paint the truck Assemble the truck Put new glass in the truck visit cash machine again rewire the truck reupholster the truck seat take out second mortgage replace the truck tires put a battery in the truck insure the truck fill the truck start the truck drive the truck park the truck sit in lawn chair with cold beer and think to myself "what the truck was I thinking when I started this process?"
Carmental | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | sounds like heaven to me.
| | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | I tried stacking washer( no good) I had to try several washers before getting combo that worked. The new NAPA master Cylinder does not have the spirals on the mating surface as OEM had so through trial and error and numerous attempts, I finally got it to stop leaking. I tried 10 different crush washer all the same size. 57 chev 3800 | | |
