8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, 1 invisible), 103 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
#879034 08/30/2012 2:04 PM
Does anyone have a drawing of the exhaust system for a '53 PU 216 engine ... all stock.
Thanks!
Dwain
Many Thanks Tim .... not sure if I can get one built using this drawing ....I'll see.
Dwain
Dwain,
That is only a general picture. Clearing the rear axle and staying below the wood bed is the main "trick".
Be sure to put this deflector on the bottom of the bed, above the hump over the axle.
I took similar diameter PVC piping to my exhaust and as Tim described bent it using a heat gun to fit. After hanging it and satisfied took it to the local muffler shop where they used it as a pattern and built me a perfect match.
Seems like a lot of concern for what I think is a pretty simple arrangement.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Thanks Tim!
Good Idea ... may try that!
Thanks!
