0 members (),
200
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I installed the new wire loom in my 53 burb, with 54 235. Now I've got couple of questions, the dash brace located between the insturment clusters has a hole with a rubber grommet in it, and I think it's where the horn wire goes? The other issue is I have a 12 volt battery, 6 volt generator, 12 volt coil, and 6 volt starter, so whats the end result-6 volt or 12 volt? I do have the resister on the coil, and everything seems to work OK. Thanks, Phil
Other than the coil all electrical components look to be original? Haven't driven it that much, just let it sit and idle, seems to stay charged.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What kind of voltage regulator do you have?
How long have you been charging a 12v battery with a 6v generator?
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | he isn't charging a 12v battery with a 6v generator! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Why the mix of 6 and 12v? Why not just switch everything to 12v? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Using a 6v starter in a 12v system (with a 6v flywheel) is commonly done with minimal problems (in a quick starting system).
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | It's possible to crank a 6V generator/regulator up to 12 volts for a short time, but it's not a good idea. More likely, the battery just hasn't run down enough to fail to start the engine yet, and the generator is doing nothing. Unless the regulator has been readjusted to take the higher voltage battery into account, I can't imagine the battery getting charged much, if any. Jerry
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Get a 12v 1-wire alternator and replace the generator and voltage regulator. Get some threaded rod and a tube and fab up a new support for the alternator. You'll need a new upper adjustable bracket for an alternator available at any parts store for cheap. (if I recall,you have a straight one and you need a curved one so you can adjust the tension)I believe that you also need to reverse the wires on your voltmeter and you're almost done. Don't forget to change ALL of the bulbs in the truck to 12 volt. And TomC, yes he IS attempting to charge a 12v batt with a 6v gen. And it ain't gonna work.
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Assuming you have a 6 volt VR, and generator Just get a 6 volt battery and coil. Done.
Kurt | | |
