8 members (Jay R, walter74, 68ironhead, carbking, baldeagle, Bill Hanlon, kades51, 1 invisible),
54
Mod | | | Forums66 Topics128,004 Posts1,055,247 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87573 11/25/2004 1:09 PM | Joined: Nov 2004 Posts: 7 Junior Member | | Junior Member Joined: Nov 2004 Posts: 7 | First off, the truck is a 1970 C-10 that my son and I are doing a mild restoration on.
The electrical problems;
#1, When I turn the turn signal in either direction, both turn signals flash along with the rear side marker lights.
#2, No rear brake/tail lights.
While removing the bumpers to start body work, I checked the wiring that I could see. No problems found. The problem was going on BEFORE bumper removal. Any suggestions???
Happy Thankgiving and thanks for the help.
"I MUST DO AS THE VOICES IN MY TACKLE BOX COMMAND" >*)))))><{
#87574 11/25/2004 2:08 PM | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | Almost sounds like you might have a bad ground back there. Is there a light plug for a trailer? | | |
#87575 11/25/2004 2:59 PM | Joined: Nov 2004 Posts: 7 Junior Member | | Junior Member Joined: Nov 2004 Posts: 7 | Big T, Thanks for the reply. Yes there is a trailer light plug. i checked the ground at the point that it was screwed into the bumper. i alos checked for "skined" placs in the wiring going to the plug.
Steve
#87576 11/25/2004 4:19 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You might have a short between the marker & turn lights. Try unpluging the front turn lights 1 at a time at the radiator support & see if that changes anything. Follow the wire going to the rear lights along the frame. Look for broken or coroded wires. I,ve got a 70 also. Great truck.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#87577 11/25/2004 5:50 PM | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | Lights act really funky when they have a bad ground. Ground the lights to the frame and replace or remove the trailer plug and go from there. Good luck and have a great turkey day every one.  | | |
#87578 11/25/2004 7:58 PM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | I think Wrenchbender is an the right track. The turn signals and running lights are two separate circuits. Somehow they have become cross connected.
Check all of those dual filament bulbs. It is surprising how often one filament will break and short to the other filament causing a cross connection.
Gord 1954 1/2 ton 235 4 speed
