6 members (bucktruck, dt235sd, Stelonlevo, Hotrod Lincoln, Mike B, 1 invisible), 104 guests, and 2 robots.
Topics128,119
Posts1,056,648
Members48,450
I want to get brand new rims for my 59 Apache (15" 6 lug) but I want to be able to install the original style repro hub caps that require the clips. Are there any new rims out there that can have the clips added? What are my options?
Glen Stringfield
Socket Breaker
Socket Breaker
If you want narrow, stock type wheels, check Jim Carter and Chevs of the 40s. Wheel Vintiques makes some that are wider, and I think they use stock caps (need to call them.) Summit racing carries some of their wheels. Coker tire has some in their catalog also. As Woogeroo said (or implied,) original wheels are your best bet..sandblasting and powder coating, just like new! Best of luck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Thanks 40casey,
I checked with Jim Carter, they have similar rim without the clips part# MST150. It looks like you would be able to drill the holes and add the clips but the woman I talked to on the phone had no clue as to what I wanted to accomplish so it looks like I'll be using the stock rims with the rivets.
Glen Stringfield
I talked to Jim Carter about them right after he started carrying them. He said the stock hubcaps won't fit but he has some plain ones that will.
That was a few years ago so things may have changed.
