1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#874825 08/14/2012 9:07 PM
I own a 49 chevy truck with a 54 chevy engine. How can I tell which 54 engine it is???..Beside engine number, is there anything physically different about the engines on the exterior??
Thanks!!
Bill M
billm #874827 08/14/2012 9:12 PM
Barry Weeks wrote an article that might help. Try here http://www.stovebolt.com/techtips/engine_identification.htm
billm #874828 08/14/2012 9:12 PM
It should have a casting number on the block and the head, this coupled with the number stamped on the pad behind the distributor will tell you what you have. Post the numbers here there is a host of experts that will decode for you.
Yes, there are physical differences between early and late 235 engines. And there are a few differences between car and truck engines.
However, the advice above is how you can find out what year engine you have.
