| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | I own a 49 chevy truck with a 54 chevy engine. How can I tell which 54 engine it is???..Beside engine number, is there anything physically different about the engines on the exterior??
Thanks!!
Bill M | | | | | Joined: Jul 2011 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 55 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | It should have a casting number on the block and the head, this coupled with the number stamped on the pad behind the distributor will tell you what you have. Post the numbers here there is a host of experts that will decode for you. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, there are physical differences between early and late 235 engines. And there are a few differences between car and truck engines.
However, the advice above is how you can find out what year engine you have.
