Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Woodcmiami, tclederman, Otto Skorzeny), 145 guests, and 3 robots.
Topics128,282
Posts1,058,496
Members48,490
#874218 08/12/2012 6:32 PM
I have a new glove box that came with 6 clips for top and bottom. When I try to line the holes up, the corners of the box are hitting against the metal dash frame. Looks like I might need to cut slits in the corners of the new box. Does anyone have any pix of their glove box?
No pics but if I'm thinking correctly the bottom cardboard lip will fit just under the lip of the metal frame. The lip where the box fits under the dash frame can be a little tricky. A good flash light and a couple minutes laying on your back and I think you'll see.....then again, I could be totally wrong!!
Moderated by  ndkid275, Phak1
