1 members (baldeagle), 142 guests, and 2 robots.
Topics128,037
Posts1,055,467
Members48,424
#87411 11/19/2004 11:29 AM
My fuel guage is stuck on 3/4, even with new sending unit installed. What else can be checked?
#87412 11/19/2004 10:32 PM
Riding in the Passing Lane
Ground the wire going to the sending unit.
Turn on key & the gauge should read empty.
Remove the wire from the sender & it should
read full. If it doesn,t check for power at
the gauge. Than try the same test on the terminal
that goes to the sender. If you have current to
the gauge & it still doesn,t move you need a new
gauge. smile
1972 Chevy c10 Cheyenne Super
#87413 11/20/2004 12:32 AM
There are some excellent trouble shooting tips available on some sites, specifically for gas guage problems. They work!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#87414 11/20/2004 12:41 AM
Check the Tech section of www.chevytrucks.org where it is well explained. Sorry John and Peggy!!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#87415 11/24/2004 10:32 PM
I gave up on trying to find my problem,installed after market stewarn warner,, new sender and gauge,, works great and right on the money,,but then if you want to keep the stock one working then as mentioned a lot of tips on the bolt,, make sure you new sender is matched up to your gauge(ohms) or it wont work,,good luck,,Fred
Redryder pix
My Hotrod
#87416 12/02/2004 7:28 AM
Sorry it took so long to update. Went to the Rod Run in Daytona and bought a new gauge. Installed it and it went to full even though I only have about 1/2 a tank and then it just kept goin! I mean the needle disappeared behind the bezel. What's up with that?
#87417 12/02/2004 11:59 PM
When the gas gauge goes way over beyond full it
indicates an open circuit to the sender or defective sender. Ground the wire at the sending
unit & the gauge should go to empty. If it does
the sender is defective or not grounded. smile
#87418 12/19/2004 4:06 PM
I have the opposite problem. No matter how full the tank, the guage always goes rapidly to the full setting when I turn on the ingnition. I just ignore it and calculate how far I've gone and figure out when to fill-up based on my MPG (which is about 15) How can I correct?
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver
1929 **** Model A Pickup - Restoration
