0 members (),
123
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | I have some play (up & down) on the drivers axle. How do I remove axle to inspect? | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Pull the pumkin cover and remove the clip. Remove wheel and brake assembly. Pull axle out. Do you have a manual? Go to Gregsonline.com to get one.
| | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | No I don't. I'll check out the site. Thanks for the advice. I thought there was a clip to pull but wasn't sure about the brake assembly and what had to come off. Does that include taking off backing plate? Or just shoes etc and brake line? I'll get the manual and find out. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Just the wheel & drum need to be removed. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Pull wheels. Remove brake drum. Pull pumpkin cover off. Remove pinion shaft lock screw and pinion shaft. Push axles in towards each other. Remove clips. Pull axle shafts out. | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | Thanks for the details. I appreciate your help. | | |
