2 members (klhansen, 1 invisible),
151
Mod | | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 4 New Guy | | New Guy Joined: Aug 2012 Posts: 4 | Hey everyone, very new to the site and had a question and could use some ideas. I have a 1949 4400 stake body that chassis is in bad shape, but cab is workable. I temp set the cab on a 1983 chevy 3/4 ton 4x4 rolling chassis/350 and it looks pretty good, but fabricating cab mounts to fit the 83's 'curved chassis' (instead of the 49's straight chassis) could get interesting, but do-able. Is there another chassis that I may want to look at that would fit a little better? (example. 4x4 straight chassis? c-40,50,60 chevys?, maybe a newer style chassis?) my ideas right now are for something 4x4 'or' maybe even going back to a 1.5 ton or larger. just looking for ideas guys, and pics would be great too! thanks | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Welcome to the Stovebolt!  You could look for a better original frame...late 1947 thru 1953 I believe should all be the same....maybe even up to 55 first series. Others will correct me if I'm wrong. I've heard others say the newer chassis have a wider tire track and don't fit under your fenders...do a search, this has been discussed before. Mike B  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Mike's right, any newer and it's a fair amount of work if it even works and likely the wheels poke out the fenders.
Original is the easy and better looking option, 48-54 frames were made to fit under that cab...
Grigg | | | | | Joined: Aug 2012 Posts: 4 New Guy | | New Guy Joined: Aug 2012 Posts: 4 | thanks alot fellas. honestly my 49' chassi is in better shape than the 83', and it will be very easy for cab,steering,etc. But since Ive put this cab on that 4x4 chassis, it looks great!! im wondering if i should use the 49' chassis, and set the 4x4 axles, eng/trans... in the 49' frame.?.? | | | | | Joined: Feb 2011 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 32 | hello, have any pics you could post of your truck oon the 4x4 frame? thanks | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The tires will still stick out if you do change the axles to the old chassis. | | | | | Joined: Feb 2011 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 32 | hey guys, what if he ran newer model rims the off-set pushes tire in (now i dont know if there would be brake clearance issue) and ran 1o.5 vs a 12.5 tire? at least it would pock-out less | | |
