8 members (Bill Hanlon, Jon G, 55shaker, Otto Skorzeny, HandyAndy, UtahYork, DadsFirstPickup, Hotrod Lincoln), 78 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#873590 08/09/2012 10:17 PM
I have a 55 235 engine in a 58 apache and the vacuum advance does not work any more . Instead of replacing the original vacuum advance is it possible to replace the entire distributor with one for a 1966 230 engine with a more modern vacuum advance?
6571 #873598 08/09/2012 10:36 PM
It can be done with machine work and money but why? Just replace your vacuum can.The distributor for engines later than 1962 will not easily fit earlier.
Bob Taylor
enginenut #873601 08/09/2012 11:02 PM
Yes, it is possible to swap for a later model dist. The hold down seat need to be machined.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
6571 #873604 08/09/2012 11:16 PM
H Online: Content
Assuming you're running a 12 volt electrical system, just swap to the HEI ignition used on the late-70's and newer engines. It's a fairly simple swap that only involves a little machine work. That eleminates the points altogether, and gives you a much hotter spark.
ODSS Lawman
ODSS Lawman
Why not just buy a new vacuum advance for $25 and be done?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #873691 08/10/2012 11:01 AM
laalaa
