4 members (Ridgeback, KCMongo, baldeagle, stlcardinalsguy), 45 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#873452 08/09/2012 2:29 PM
Wandering how to get the glass out of the metal holder for a 1940 truck
brickman #873595 08/09/2012 10:30 PM
Soak it with some gas? If you can get a small screw driver and CAREFULLY get it between the metal and the glass the metal frame may come loose.......but don't break it!!!
Achipmunk #873643 08/10/2012 5:56 AM
I found spray-on brake cleaner to be really good dissolving glass setting tape. I think a spray can of gasket remover would do it too.
1951 1 Ton Completed
truckernix #873666 08/10/2012 9:20 AM
Ok thanks guys!!!
brickman #874188 08/12/2012 4:12 PM
soak it in brake cleaner then put a wooden dowel on the edge of the metal frame next to the glass and hit the dowel with a rubber mallet should knock ihe frame off
leonard #874394 08/13/2012 11:19 AM
Brake cleaner worked swell. Got the driver side glass out f the track. Now can start the passenger side. Thanks guys for the tips helped out a ton!!!
