4 members (78buckshot, Wally / Montana, FishinToms53, klhansen), 57 guests, and 2 robots.
Topics128,053
Posts1,055,778
#868823 07/23/2012 1:04 PM
Hi All,
I cannot seem to figure out what bolts are still holding my seat frame to the seat base. I have a 1950 AD truck and I am trying to remove the seat/frame completely out for painting. Is there any pictures available?
rc,It depends what you've already removed,I found it much easier to remove the frame complete with the runners etc.
There are two 1/2" nuts at the rear of each runner on the vertical panel of the seat base,have you removed these?
Also be careful when you finally remove the seat it's awkward and pretty heavy.
More pix on Flickr.
The frame is held on the sliders with 4 bolts that stick out the top of the sliders themselves. They are in the recesses on each corner of the frame. These are studs not bolts, so you need to clean them and use PB Blaster or similar on the threads. They are easy to break if you don't. Since you have a 1950 the seat frame is also held on the sliders with small bolts and a clamp on each side for the cables that runs through the back of the frame. These are 1/2 way down the frame on each side. If you look at the picture you can see the bolts and the clamp assembly on the side of the seat frame.
http://good-times.webshots.com/photo/2731952780102454676kbLHxp
Thanks for the picture, wow you have a nice truck. I managed to get the frame out last night, I remove every bolt I could see but things where a bit rusty so it did not come out easy. I won that battle but now to deal with the rust!
How about removing the seat from a 41 Ak pickup ?
Gotta Love Old things, Old ways, old times, Old Vehicles
Moderated by  ndkid275, Phak1
