0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All,
I cannot seem to figure out what bolts are still holding my seat frame to the seat base. I have a 1950 AD truck and I am trying to remove the seat/frame completely out for painting. Is there any pictures available? | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | rc,It depends what you've already removed,I found it much easier to remove the frame complete with the runners etc.
There are two 1/2" nuts at the rear of each runner on the vertical panel of the seat base,have you removed these?
Also be careful when you finally remove the seat it's awkward and pretty heavy. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The frame is held on the sliders with 4 bolts that stick out the top of the sliders themselves. They are in the recesses on each corner of the frame. These are studs not bolts, so you need to clean them and use PB Blaster or similar on the threads. They are easy to break if you don't. Since you have a 1950 the seat frame is also held on the sliders with small bolts and a clamp on each side for the cables that runs through the back of the frame. These are 1/2 way down the frame on each side. If you look at the picture you can see the bolts and the clamp assembly on the side of the seat frame. http://good-times.webshots.com/photo/2731952780102454676kbLHxp | | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Thanks for the picture, wow you have a nice truck. I managed to get the frame out last night, I remove every bolt I could see but things where a bit rusty so it did not come out easy. I won that battle but now to deal with the rust! | | | | | Joined: Jun 2012 Posts: 11 New Guy | | New Guy Joined: Jun 2012 Posts: 11 | How about removing the seat from a 41 Ak pickup ?
Gotta Love Old things, Old ways, old times, Old Vehicles
