4 members (Peggy M, klhansen, Wally / Montana, Hanks custodian), 82 guests, and 3 robots.
Topics128,059
Posts1,055,823
#872697 08/06/2012 8:39 PM
I have about 400 miles on my rebuilt 1958 261. Should I change the oil now or put more miles on the motor? Thinking about running 10-30 Pennzoil. Looking for feed back.Thanks Pat
pf
You can't change it to often on a fresh engine.
Does it have a full flow or by-pass filter?
My Blog
Yes. Change the oil. Then change again after another 1000 or so.
Builder #872748 08/06/2012 11:03 PM
Sounds like a plan. Full flow oil system
Thank you
pf
patspanel #873298 08/08/2012 10:27 PM
My old-school engine rebuilder recomended I use Shell Rotella diesel oil. He said it has more of the additives we need for our old engines. He also has me adding ZDD (zinc) to the oil to give the lifters/cam the protection they need. Modern engines don't need zinc because they have roller lifters.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #873308 08/08/2012 10:42 PM
+1 on the Rotella, either straight 30 weight or 15W-40. Especially if you're running a fresh cam and lifters, the extra ZDDP additive in the Diesel rated oil will help prevent premature wear on the cam.
Actually Chevron supreme does pretty good on the EP test. Though I think it was 10W-30. In old school 235's I say old school
SAE 30. I don't think Rotella is what it used to be either.
What year is an old-school 235?
Chevrolet started recommending multi-grade oil in 1954.
