4 members (Oswald, Peggy M, 2-Ton, Hanks custodian), 364 guests, and 2 robots.
Topics128,160
Posts1,057,050
Members48,463
Anyone have experience with buying and installing one of these preformed headlinders. My 1952 truck is of the street rod type. Thanks.
Nick Burton
I installed the cardboard type and it looks good and was not that hard to install.
Pete
NickO as you have probably learned, there are pretty limited choices for pre-formed headliners. The ABS ones generally are made to be covered with cloth or other material. I didn't want that for my truck so I went with a fiberglass unit. I think the installation would be similar for either one.
I am happy enough with the finished result but it is the least well done part of my truck in my opinion. I had 3 basic issues and all could be avoided with better planning and experience on my part.
If you go with a fiberglass unit it is designed to be painted. I had the paint store color match my seat and door panels. I didn't want shiny paint and asked them to add flattener. They didn't seem sure how much to add and indicated that was usually the painter's decision. Anyway, it came out shiny despite the chalk they added to the paint.
My second issue caused the third issue. I had only my wife to help me position and mark the headliner before trimming. I know better then to use my wife but sometimes there is no choice. Even under good circumstances it is somewhat challenging to hold the whole headliner tightly in all areas to mark for trimming with only 2 people. In the end I removed to much material from the side she was holding up and ended up with a gap above the door. I resolved this by adding metal strips above both doors so it looked planned. The metal strips may have been necessary anyway because the fiberglass wanted to curl inwards in this area and only the windlace holds it.
In retrospect, I think this fiberglass headliner may have fit almost exactly with very little trimming if you position it in just exactly the right spot. To accomplish that might take 5 people (4 holding and one marking any areas to trim) or put in in with the cab upside down.
You can see how mine came out here
http://s99.photobucket.com/albums/l...?action=view&current=IMG_3016JPG.jpg
Chuck
Thanks for the info on the headliner. Where did you get yours and cost. Thanks so much!!!
Nick Burton
1 Offline
That looks real good Chuck! Where did you find it?
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Both Jim Carter and Brothers had them and probably still do. I don't remember the exact price but the shipping cost was almost as much as the headliner. The funny thing is both companies quoted me a much lower shipping cost initially, changing it to exactly the same price later. They both claimed to have it in stock but how does it cost the same to ship it more than halfway across the country as it does to send within the state?
I initially canceled my order each time the shipping changed but in the end I didn't like the cardboard at all and just paid the price to get the fiberglass. If I had to do it over again I think I would go the same route. Just not repeat my mistakes.
Chuck
I bought the abs / plastic headliner from Classic Parts. Maybe I'm just lucky but I installed it with out help & it fits good. Just needed some trimming over the channel for the door windlace
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
Moderated by  ndkid275, Phak1
