Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (1955 1 Series, Otto Skorzeny), 111 guests, and 5 robots.
Topics128,277
Posts1,058,456
Members48,490
Help !!!! is there a trick to removing/installing the floor board on a 1941 4 speed. I tried every gear and hand brake settings and there seems to be no way to side that thing off or on...
I like fixing stuff.
It's been a while, but if I remember right you have to turn that sliding plate on the e-brake handle kind of sideways while the floorboard is part way up and slip the sliding plate through the floorboard, then the floorboard will come up and over. I don't remember if the part of the floorboard that the pedals go through has to be removed first, but i know that the two pieces have to be apart. Hope this helps.
Opportunity is missed by most people because it is dressed in overalls
and looks like work. - Thomas Edison
1941 AL 3/4 ton 125-1/4 WB, bought by my Great Uncle Matt in 1942. Still in the family.
Have you removed the shift lever? Very easy--just push down the dome shaped retainer at the base of the shifter, turn 1/4 turn left, and pull out lever. Easier to stab back in if trans is in neutral.
Evan
Seems that I got mine out several times just had to move the e brake so the handle was right along side the shift lever. Also had to work it past the pedels by depressing them and sorta poping the floor past them.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
thanks to coilover 1/4 turn left.. thats easy.... what a pain in the butt trying to work under the pan when its taped up the top of the shifter because you cant take it out... or you have to remove the top of the tranny... why isnt this in any manual,,, thanks guys
Socket Breaker
Socket Breaker
old trucks are fun!
-W
