1 members (Wooley), 90 guests, and 3 robots.
Topics128,096
Posts1,056,488
Members48,444
Is there any overdrive to use for my truck?? Now i dont feel good doing more than 70km/h(about 45mp/h).I wanna go faster eeeek
Your choices are an O/D transmission, larger diameter tires or a higher ratio rear end gearing or two speed rear perhaps. You'll need to post what you currently have for the BigBolt gods to be able to help. The full model, gvwr, model year, etc. is all of help.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Conny,If you have a 2-speed rear-end,as I'm pretty sure you do,(6500-Series,probably 18,000 gross),you may have "her" set in the "low-side",(rear-end gears). Mine was set on the "low-side",and my top speed was around 40-45,if I pushed it. I found the answer here on Stovebolt,so I thought I should pass it on. Hope this helps. B.T.W... Now I can run comfortably (without over-revving the engine) at right at 55 M.P.H. Fast enough for me,but I don't use the Interstate,either.
Mo' Tater
You can get a ranger overdrive http://www.advanceadapters.com/products/pn-760001m-27/ this is what I have installed on my truck to help bring the rpms down when Im on the highway, I also replaced the ring and pinion gears with a 4.88 ratio. So now I can cruise at 65 turning under 2500 rpm.
I have a gear vendors OD unit in my motorhome and it is very slick. Has a magical box that automatically shifts it into OD when I hit 40. Has a dimmer switch on the floor to shift out of OD when needed. Expensive but slick, thankfully my MH came with it.
I have a OD Brownie box in my 46 GMC. It works fine but nothing like the GV unit.
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
