3 members (Bill Hanlon, DadsFirstPickup, Otto Skorzeny), 75 guests, and 2 robots.
Topics128,154
Posts1,056,840
Members48,456
#872433 08/05/2012 9:55 PM
I am working on a 1945 1 1/2 ton and would like to get the correct wrench/socket to remove and replace the rear axle/hub bearing retaining nuts. They are large round nuts that have a number or slots in them to be grabbed by the special wrench/socket. Any idea where I get this?
Your local Napa or other parts house will be able to get them if they don't have them on the shelf. You just need to measure the size.
Lots of folks use chisles and punches to remove and install them.
Jeff
My 1953 Chevrolet
1947.1 Gallery
H Online: Content
I've made my own axle nut spanners for years- - - -pieces of pipe with square key stock welded to the outside, and a pry bar through a hole in the pipe for leverage. Sometimes it's necessary to turn the pipe down in a lathe a little to get the right diameter before welding the key stock on.
The one you're looking for is probably sold as a front 4wd spindle nut socket. I took a nut to the auto parts store and that's what I ended up with for the rear of my truck. Forget the price but it was quite cheap (and works well).
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Jeff
But please don't be one of them. Get or make the proper tool.
If you can take a picture it may help the store (or us) to give you a better answer.
Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
