8 members (BC59, David Bush, MikeE, Bucker, MickeyP, Rexville48, dt235sd, Forty9), 88 guests, and 1 robot.
Topics128,049
Posts1,055,702
I just brought home my '50 Chev pickup 5-window, and am having a great time fooling with it. One thing I noticed though, is it tends to stall when I turn a corner, and idle down. I wonder if is just idle speed, carb float level, or maybe vapor lock from heating up on a 100+ day.
Any ideas?
Ed Burgess
"It's all good!"
Not many of us up here have experience driving on a 100+ day! However, I would certainly check the float level.
1951 1 Ton Completed
Float level gets my vote!
Could be a loose or frayed electrical wire problem.
1939 Chevrolet Stake Truck
With fire or gas to suspect, I'm in agreeance with Rick.
I'd probably check the coil wire connections first.
Good luck!
