5 members (3B, Otto Skorzeny, 55shaker, rick46ia, 57 Drifter), 73 guests, and 1 robot.
Topics128,023
Posts1,055,365
Members48,420
#871601 08/02/2012 5:48 PM
I know this has been discussed but, I have a 54 with a 235 which is a 1958 engine. I have a 95 camaro RS rear. What would be easiest trans to install? I have a 350 turbo but have been advised not to use?
che57vy #871635 08/02/2012 8:03 PM
This is not an instant answer board. Are you wanting an automatic that will bolt up to a 235? Why do you want to go "the easiest" way? Why not the best for what you want to use the truck for, whether easy or not?
Cletis #871646 08/02/2012 8:24 PM
what transmission do you have in it now..
might be some good tips here
Redryder pix
My Hotrod
Cletis #871817 08/03/2012 10:15 AM
well what you said is what I meant not to be scolded
joker #871818 08/03/2012 10:16 AM
I do not have one in right now thinking of going with a s-10
che57vy #872079 08/04/2012 3:50 PM
Did anyone give you a reason for reccomending not to use the TH-350? It's a direct-drive trans, no overdrive, but it's about as reliable as a sledgehammer. There are adapter plates available to fit the back of the 235 block that will let the 350 bolt up to it. Of course, the early 700R4 without the computer control will fit the same adapter if you need an OD gear.
If you want an OD manual shift, the S-10 trans is a pretty good choice. Most of them need a little modification to the input shaft to work properly, or a spacer plate between the trans and the bellhousing is another way to handle the slight length difference of the input shaft.
Riding in the Passing Lane
If it is set up for a manual trans. that is the bast way to go. If you put in a modern auto trans you will have to remove the crossmember under the bell houseing. The S-10 5 speed is a good way to go but a lot depends on your rear end ratio.
1972 Chevy c10 Cheyenne Super
Thanks, I have been pondering over this for some time,I have a fresh 350 turbo but the reviews I have read are not so good for the automatic as they do need to spin to get power out so that robs engine, reviews I have read that the adapter kits are so expensive. And have been breaking the flex-plate.My question is the s-10 5 speed, I know there is a ford pattern behind the four cyl and GM 6cy are GM pattern, so what I want is a trans out of a V6 with removable bellhousing ?
che57vy #872295 08/05/2012 12:03 PM
Yes. You need one from a S-10. It doesn't have to be a V-6 though. The best one to use is from the mid 80,s. It was used on both 4 & 6 engines. It has the mechanical speedo drive. Most 88 & all 89 up have an electronic speedo drive & ceate a problem for the speedo. There is a tag on one of the bolts for the rear houseing. It has an ID # on it. 1352-xxx. Sometimes this # is on top of the trans on a sticker. 1352-145 is the best one. If you get this # you can ID the trans after bringing up a chart on the internet. It gives the ratio of the trans. Again the desireable ratio will depend on your rear end ratio.
Thanks I see some 89 models had the digital speedo which was a option after that 90 on digital speedo. I have a 95 camaro disc brake rear. Thanks a bunch
