| | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Howdy fellers,
This is for my commuter car, so I'm breaking rules, but hey, I know where to come for answers...
Just replaced the clutch, and now it's hard shifting and it grinds trying to shift to reverse, so obviously the clutch is spinning some with the pedal pressed. I adjusted the clutch release lever both ways well past specs and well past the typical full engagement point on the pedal travel (about half inch or so before full let off of the pedal). This means I adjusted from the point when the clutch never quite fully disengages at the bottom of the pedal all the way through to where the clutch never quit fully engages at the top of the pedal. Nothin' doin'... Only thing I can think of is that I must have cocked the pilot bearing when I bolted up the transmission. Any ideas is greatly appreciated!
Dave
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | If its a hydraulic clutch check that its bled and the master and slave cylinders are working properly.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | It's a mechanical linkage and cable.
Dave
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I've got to ask...did you put the clutch disc in backwards? Mike B  | | | | | Joined: Aug 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 45 | All clutch plates have a wave spring between the friction materials. This allows for a slightly smoother engagement. Some also have too much wave in the spring, spreading the friction material to far apart reducing the clearance between the flywheel and the pressure plate. There is always some clutch break-in required with new clutches to get the fuzzys off. Some times just letting it set for a few days, will let things compress and it will work just fine. Hope it does not have to come back apart. Good luck.
The older I get, I only want to work on older rigs.
| | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | 99% sure the flat is against the flywheel and the pressure plate is flush (not to mention the "Flywheel Side" inscription). But there's always that doubt, though...
Thanks, Joe. I was curious how much clearance you have with the finger springs fully compressed. Too bad I can't get in there easily. I did burn it in pretty well now, about a month driving and riding the clutch every now and then.
If anyone's had a problem with a cocked pilot bearing (from installation) and had to pull the transmission back off, I'd be curious to know the symptoms. Mine also still squeaks for a while until it's warmed up.
Dave
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Is it possible that the throwout bearing is installed backwards?
Just a thought that fits the description of problems.
Best wishes,
Les | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Naw, that only goes in one way on this car; there're tangs for the fork to grab. Plus everything feels like it's a correctly installed clutch when disengaging and engaging; no rattling, smooth, typical force of a new pressure plate when pressing the pedal, smooth semi-grippy engagement of a new clutch, and no abnormal sounds (other than squeaking while cold).
Dave
