| | | Forums66 Topics128,150 Posts1,056,821 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | I'm in the process of replacing the driveshaft middle u-joint and carrier bearing on my 1959 38. I removed the rear driveshaft and unbolted the center bearing carrier from the cross member. My question is: how do I remove the carrier bearing from the front driveshaft? Gear puller? Press? I wish to benefit from someone else's experience instead of going about this in the most difficult manner possible (my usual MO).
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had mine done as I took the piece to a shop. I believe they used a press. | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Im doing the samething now, what did you do are you done. | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Thx tucker, I got it off with alot of pounding and heat. | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | I finally surrendered and did the same as Truckernix. I took it to a shop nearby. Fifteen minutes, ten bucks and done.
