2 members (frogfarmer, Otto Skorzeny), 102 guests, and 1 robot.
Topics128,154
Posts1,056,855
Members48,456
#857826 06/10/2012 12:13 AM
I'm in the process of replacing the driveshaft middle u-joint and carrier bearing on my 1959 38. I removed the rear driveshaft and unbolted the center bearing carrier from the cross member. My question is: how do I remove the carrier bearing from the front driveshaft? Gear puller? Press? I wish to benefit from someone else's experience instead of going about this in the most difficult manner possible (my usual MO).
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
I had mine done as I took the piece to a shop. I believe they used a press.
1951 1 Ton Completed
Im doing the samething now, what did you do are you done.
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
Thx tucker, I got it off with alot of pounding and heat.
More pix on Flickr
I finally surrendered and did the same as Truckernix. I took it to a shop nearby. Fifteen minutes, ten bucks and done.
Oldbolter
Moderated by  Dusty53
