7 members (52Carl, joe apple, Otto Skorzeny, 55shaker, Gray_Ghost, Hush, JW51),
147
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Project just starting.
The truck is almost impossible to move even when it is out of gear, well at least we think its out of gear. It doesnt seem like the parking break is on and the brake lines are missing, so i wouldnt think they would be locked down. If you jack up the rear end and try to turn one wheel manually you can't get it to budge. Any ideas. Also, does anyone know what weight of oil to use in the rear end? It is a 1950 3600.
1950 Chevy 3600
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Brake shoe is rusted to the drum. Take the tire off, and tap around the outer edge of the drum to see if it will free it up. Make sure you block the truck up while you do this. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | That plus use any good 90wt. gear lube or 75 to 120
I would bet it's the brakes as Roy said,you could try adjuster and try adjusting them in.
Pete | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | ill try adjusting them. i had taken them off a few weeks ago too see what the brake shoes were like, and they were in good shape. Ill see if they are too tight.
1950 Chevy 3600
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Make sure to use a single grade 90W gear oil.
Are both wheels locked-up with both wheels off the ground??
What happens when you remove drain plug from axle???
Any water or rust colored oil???
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | A good way to remember which way to tighten most brake shoes: if you bang your knuckles on the spring while holding the brake spoon, you are going the correct way.
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | With Both tires off the ground and the truck out of gear it wont turn by hand. the truck will roll, but i had to use a come-along even with four inflated tires... It could be that its actually still in gear when i pull it out i guess... it is a 4 speed.
1950 Chevy 3600
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | when you were moving it with the come along did you have the hood up to see if the engine was turning? take the spark plugs out, try to turn the engine, if it's in gear you won't be able to, but it should roll easier  Bill | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Ill raise the hood and winch it today and see if the engine is turning.
1950 Chevy 3600
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Take the brake drums back off again and bolt the wheels on without them. If it moves it's brakes, if not it's in the driveline.
Evan
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Coilover
Yep i had one break that was locked up. Now it is fixed. Next problem is i dont know if its going in gear because im trying to turn the motor over by leaving it in gear and winching it forward, but the motor doesnt turn over. I have pulled the oil pan and the cylinder walls, cam, crank, all look fantastic. I have put some mistery oil on top of the cylinders per someone else on this boards recommendation, but still wont turn over. Cant get it to turn over by turning the bottom pulley either...
1950 Chevy 3600
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Still could be some surface rust on the top side of the cylinders that you can't see. | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Did you remove the drum when you inspected the brake shoes? I missed something here. If you haven't already, pull the spark plugs and then check to see if the engine will turn... in case there is a stuck valve issue. Are you going to rebuild the engine? Jerry | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Take the sheet metal cover off the bottom of the bellhousing, and use a pry bar on the starter gear teeth to try to turn the engine. I like to use the straight end of a carpenter's wrecking bar wedged against the bellhousing and engaged into the flywheel teeth. Just be careful not to break any teeth off the flywheel gear. Work the flywheel back and forth a few teeth at a time until you can get a full turn. Jerry
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Thanks Hotrod. I will try turning the flywheel this evening.
1950 Chevy 3600
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Motor turns over! Thanks for your help. Does anyone know how to remove the timing gear cover. I cant seem to figure out how to remove the pulley in front of it and it is blocking two of the bolts that hold it on.
1950 Chevy 3600
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | What gear do you put it in when you try to winch the truck in gear? Try a high gear. | | |
